Another Issue - FirebirdV6.com/CamaroV6.com Message Board
Another Issue
  • Another Issue
    Another issue
    LOL...alright here is the problem now....I am not sure about turbos so its weird to me...but I was running 10 psi around town and I didnt even know it...lol how exciting cause my mechanics friend mixed some hoses up on the electronic boost controller...but since I got those turned around when I go to floor it again....its like I am hitting a rev limiter at 4 thousand rpms....I mean I dont understand that at all....so I guess I have to look around with hp tuners to look at my rev limiter......cause I need to know......like when I hit 5 psi it stays there and so does my rpms...?
    2002 Firbird, <br />STS GT35mm-61 Turbo, HP Tuners, 3.73,UMI LCAS,UMI Panbar<br />Nitto NT555R P245/50R16 96v, NGK spark plugs t55, transgo shift kit, Jet servo
    Re: Another Issue
    Originally posted by Bankz27
    Another issue
    umm E-boost should be on the top and boost line should be on the bottom of the gate right?
    www.turbov6camaro.com
    1997 3800 Series II Camaro
      Re: Another Issue
      well lets see the way he had he the the line going to the T was suppose to go to the STS pump but was going to the regulator but I fixed that issue so i am going to just go with an manual boost controller to avoid this...but main issue is that my car stalls at 4k rpms at 5 psi and doesnt go anyfurther then that....set at 5 psi
        Re: Another Issue
        i think something is hooke up what do you mean "T" and STS pump
          Re: Another Issue
          hahahahaha.......I'm sorry dude took me awhile to figure it out....but since I have eletronic boost controller here is how the setup goes
          wastegate top - goes to sts controller top
          wastegate bottom goes to regulator and turbo with T line
          regulator goes to sts controller bottom
          STS controller has electric wire that goes to the switch
          switch goes to 12 volt and goes to ground
            Re: Another Issue
            so I figured out what was going on...lol but I get a tail BOV in red for 200 bucks which includes shipping and custom front intercooler for another 200 dollars from Texas rear turbos.......I am really excitied even though my car is still working right...hahaha
              Re: Another Issue
              Since all bs is out of my system I started reading some of what is going on....my EBC is basically hooked up wrong and so right I am not leaving it alone at 5 psi...something I can fix in the future...but next issue
              My car shuts down every couple of seconds. For example at the stop light I lose some battery power, car exhaust stops then picks back up, and engine feels like it is going to die...I dont know how to solve that issue..
              Next issue I am having at 10 psi and 5 psi I am having the same issue. Issue is when I press on the gas to go when I hit max boost my car like stalls, bogs down and I dont go anywhere while the gas is floored so I let off it. I am not sure about this issue either. It stalls at 4 thousand rpms or max boost and then at 5 psi I can 1 mph a minute. I dont know if the EBC has something to do with or not but would be good to know.
              ________________________
                Re: Another Issue
                Alright I am the fix part of this adventure....here is what happen....I get oil spraying out of my ehaust or turbo...which I dont think is good...probably running rich so I am not sure how to tune that out...but I still get the same issue of once I press the gas and hit 4 thousand rpms and 5 psi its like my car dies....
                  Re: Another Issue
                  sound like maxed MAF or the maf delta is maxing and putting you in limp mode
                    Re: Another Issue
                    I was thinking that too as well looking at your tune site...talk foff667 about it real quick see if he get me a config file to help tune for that....pleaseeeee
                    I quess I will try and doing it myself as well...how fun
                      Re: Another Issue
                      also...when I did check that I believe everything from 2800 plus was like 4.56 not sure
                        Re: Another Issue
                        we are working on your tune....... i think i found the problem, try the ones hes going to send you and report back with a scan
                          Re: Another Issue
                          I am praying it works....right now as I speak at work wanting to get home load it up and listen to my car go down the street..running right.
                            Re: Another Issue
                            Best of luck!
                            Tuning is above me.... I hope all is worked out..... I wanna see this bad @ss car!
                            Ahhhhhhh, another *****in car added to the east coast! :)
                            • Manimal
                              Coil springs
                              by Manimal
                              6 days ago
                            • Manimal
                              Newby here
                              by Manimal
