ok im setting my car up with a T4 turbo kit. What size fuel injectors will i need to have to run 8-9 PSI and what are our stock injectors?? is there anything else i will need to upgrade on my car besides a fuel pump also to run this??
T4 turbo questions
Re: T4 turbo questions
on fuel side no.
You would need to get a tune
22# are stock, you would like to get at least 36#
Use this to calculate the size of your injectors:
http://www.allmod.net/hpt/injectors.xls
