For people whos planning on running boost - FirebirdV6.com/CamaroV6.com Message Board
  • For people whos planning on running boost
    Upgrade your injectors and fuel pump!!! Although my car is running strong still, I know something is wrong inside the motor. I think it was caused by running 4lbs of boost with the stock injectors. Don't make the same mistake!
    That is all.
    1997 Camaro Y87. Turbo.<br /><a href=\"http://pureoctaneracing.net/\" target=\"_blank\">Pure Octane Racing</a>
    Re: For people whos planning on running boost
    Im running a turbo charger aswell... and im runnin 7psi and its no problem at all... I have a FMU system tho but didn't change my injectors... aftermarket Fuel Pump.. thats it for fuel and its fine mechanic pulled it all apart to see if it was ok and everything still looked great,,,
    Dan
      Dan
      Thats weird. I had a Vortech FMU and Walbro fuel pump with stock injectors and my car kept losing power if I had the throttle all the way down. I drove all the way to Florida like that and noticed that my car was starting to get oil in the tailpipe. So, after I came back home, I upgraded my injectors and it was like Whoa when I floored it.
        injectors + fuel pump + tune > FMU
        www.turbov6camaro.com
        1997 3800 Series II Camaro
          Yeah, I know. I will be saving up for the HPtuner over the summer. Hopefully I will be ditching the damn FMU before the racing season is over.
            I've not even got all the bugs out of my turbo setup, but what i like about having the FMU and the inline fuel pump is that I have the pump come on only when boosting by hooking up a switch to the FMU. If i went with 36lb injectors or bigger... and ditched the FMU how difficult would it be to keep my setup with the fuel pump? Could I just leave the vacuum switch in place? It t's off the FMU but I guess it could just be at the end of a vacuum line???
            1997 silver Camaro RS<br />|T-Type Powered|<br /><a href=\"http://www.kwfbody.com\" target=\"_blank\">Looking for a local F-Body club in K/W, Ontario, Canada?</a>
              yeah that would
              while this setup it nice if it fails one time you motor will pop and you won't know its abot to happen till a rod goes out the oil pan
                Your setup is not depended on FMU at all, it just takes the signal from same source as wastegate, bost gauge, etc.
                I agree with viper, the life of fuel pump is the same as life of the bulb, if you go and do on/off/on/off on the switch regular bulb will burn in 24h , but if you just leave it on , it will last for a year. The fuel system is not something that I would around , I did intank Walbro and will do 36# for the begining(right after my HPT arrived)
                  That is all.
                  Good call.
                  Matt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
                    I have 42.5 injectors the walborrow fuel pump and I still need a fmu....grrrr
                    2002 Firbird, <br />STS GT35mm-61 Turbo, HP Tuners, 3.73,UMI LCAS,UMI Panbar<br />Nitto NT555R P245/50R16 96v, NGK spark plugs t55, transgo shift kit, Jet servo
                      how ????????
                        how ????????
                        u are maxing out on 60 lbs injectors....at what 15 psi
                        For right now I dont really need the fmu but for my future purposes I got to pick one up cause I plan on running 15psi+ to 20psi...depending on the build of the motor...but we shall see after I pay a visit to the tuning doctor
                          yeah but my AFR is 10:1 to rich lol
