installing turbo this weekend.. - FirebirdV6.com/CamaroV6.com Message Board
  • installing turbo this weekend..
    Yup thats right. The T70 is going on this weekend...Im doing a custom set-up and this is what i have....
    FFF piping
    T70 Turbocharger
    BLITZ racing BOV
    HKS wastegate
    X02 Racing intercooler
    Vortech 6:1 FMU
    and of course the gaskets and oil feed/return lines. I will also hafto pick up a MSD fuel pump this weekend before i can take her for a drive after the turbo
    I also have one question.....I have Pacesetter headers and i was told i would hafto cut some piping about 2-3 inches to make the turbo manifolds mount up. What piping will i hafto have cut? the Header piping themselves or the Y piping????
    Im planning on this taking a MAX of 2 days to do with everything going smoothly..im prolly gonna be doing it myself and if i had some help it would prolly only take 1 day. I only plan on running at 7 PSI cause well, this is my daily driver...when i go to get it dynoe'd i might have it turned up to 10 PSI only for the dyno.....
    Juiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
    Re: installing turbo this weekend..
    You can give the turbo to me if it doesn't work out :D
      You'll need larger injectors before you run more than 7 PSI. You may need larger injectors for anything above 5PSI. Approch this cautiously.
      Patrick<br />Sick Sixx Member<br /><b>97 Mystic Teal Camaro</b><br />425RWHP @14PSI<br />Old setup:<br />330RWHP @7PSI 13.9 @ 106.6 <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=4\" target=\"_blank\">Mods</a>
