weak fuel pump? - FirebirdV6.com/CamaroV6.com Message Board
weak fuel pump?
  • weak fuel pump?
    grrrrrrrrrrrrrrrrrrrrrrrr
    okay
    new stock FPR (intense FPR does NOT fit the camaro)
    new fuel filter
    walbro = 8 months old (ZZP)
    MSD adj FPR with boost referance installed, set base PSI at 50-51
    if i give it gas to biulds boost like up to 8 psi it adds 8 psi fuel = cool
    but if i go WOT at 16-17 psi the FP drops to 44 PSI
    www.turbov6camaro.com
    1997 3800 Series II Camaro
    Re: weak fuel pump?
    Sounds like your running out of fuel... IE. using it faster then the pump can keep up with....
    Patrick
    Sick Sixx Member
    02 4x4 Metalic Gray Tahoe LS
    01 NBM GTP
    97 Mystic Teal Camaro
    400+RWHP
    Old setup Track time:
    13.9 @106
    Patrick<br />Sick Sixx Member<br /><b>97 Mystic Teal Camaro</b><br />425RWHP @14PSI<br />Old setup:<br />330RWHP @7PSI 13.9 @ 106.6 <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=4\" target=\"_blank\">Mods</a>
      Re: weak fuel pump?
      When you put in the FPR did you adjust (set) with vacuum line attached or disconnected?
      Mod Edit: sorry didn't mean to edit your post i hit edit instead of "quote"
      THE ORIGINAL 3800SII turbo...<b><i>NOW SERIES-III</i></b>
        Re: weak fuel pump?
        Originally posted by nocutt
        When you put in the FPR did you adjust (set) with vacuum line attached or disconnected? car was running vacum attached
          Re: weak fuel pump?
          I think its time for you to put twin pumps :)
            Re: weak fuel pump?
            I think you just need to ponie up and get the racetronix kit.
            [ full bolt on\'s and blown.]<br />[formerly known as naptown]<br />[just know that im teh man ]
              Re: weak fuel pump?
              :burn:
                Re: weak fuel pump?
                To set base fuel, you must reference it with atmospheric not engine vacuum, so vac line should be detached when setting...
                  Re: weak fuel pump?
                  okay err
