i bought a Vortec 6:1 FMU, im gonna get the MSD high pressure fuel pump and i already have HP tuners. With my T70 setup, whats the max PSI i can run safely with the FMU, TR-6 plugs,high pressure fuel pump and HP tuners before i will hafto upgrade my injectors??
max PSI i can boost too??
Re: max PSI i can boost too??
I'm sure someone else will answer this with a more specific answer, but with the turbo you will find yoruself running out of injector very fast. The T70 is a big turbo and I would guess you're going to start getting close tomaxing the injectors around 8-10psi even with a good tune.
You can always test and find out, just keep a close eye on the logs and see when you are running into over 80% duty cycle.
7-8 psi and 9-10 in hot weatherwww.turbov6camaro.com
1997 3800 Series II Camaro
don't go over 7 PSI with changing out those injectors!Patrick<br />Sick Sixx Member<br /><b>97 Mystic Teal Camaro</b><br />425RWHP @14PSI<br />Old setup:<br />330RWHP @7PSI 13.9 @ 106.6 <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=4\" target=\"_blank\">Mods</a>
Originally posted by PathogenI've gone as high as 15psi, intercooled... stock motor, 42# injectors.
j/k
nice to see your still alivewww.turbov6camaro.com
Originally posted by Linxsdon't go over 7 PSI with changing out those injectors!www.turbov6camaro.com
