ok i have the intercooler mounted and everything and now i moved onto the installation of the Y pipe. I have a 98 so i know it hasto be cut 2-3 inches which it was cut 2. Everytime i try to mount them up it doesnt even look close. I have pacesetter headers also thats why i know it had to be cut. What im having trouble is getting the turbo flange up and through and keeping the Flanges that attatch to the headers align. When i do get the turbo flange up and through, it throws everything off....is this kit miss fabricated or am i missing something??
need help fast...
Re: need help fast...
Originally posted by Kidcamaro98ok i have the intercooler mounted and everything and now i moved onto the installation of the Y pipe. I have a 98 so i know it hasto be cut 2-3 inches which it was cut 2. Everytime i try to mount them up it doesnt even look close. I have pacesetter headers also thats why i know it had to be cut. What im having trouble is getting the turbo flange up and through and keeping the Flanges that attatch to the headers align. When i do get the turbo flange up and through, it throws everything off....is this kit miss fabricated or am i missing something??www.turbov6camaro.com
1997 3800 Series II Camaro
what part are they gonna hafto re-fit...the manifold bolt up part or are they gonna hafto extend the piping itself
also is there any way it can be done without driving to a shop...my whole car is kinda in pieces right nowJuiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
Originally posted by Kidcamaro98what part are they gonna hafto re-fit...the manifold bolt up part or are they gonna hafto extend the piping itself
y-pipe is the big thingwww.turbov6camaro.com
Originally posted by Kidcamaro98alright this sucks
thanks for your helpwww.turbov6camaro.com
ok well my dad ended up helping me and he was a mechinist for 15 years and hes a real good welder so we measured up the piping and cut where we are gonna add extensions. tomarrow im gonna pick up like 6 inches from a auto store and hes gonna weld it in for me. thanks againJuiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
Originally posted by Kidcamaro98ok well my dad ended up helping me and he was a mechinist for 15 years and hes a real good welder so we measured up the piping and cut where we are gonna add extensions. tomarrow im gonna pick up like 6 inches from a auto store and hes gonna weld it in for me. thanks againwww.turbov6camaro.com
I hope youinstalled the cold side of the pipes. If you did not you might end up having to modify those as well. It all depends on where the turbo flange ends up.....Patrick<br />Sick Sixx Member<br /><b>97 Mystic Teal Camaro</b><br />425RWHP @14PSI<br />Old setup:<br />330RWHP @7PSI 13.9 @ 106.6 <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=4\" target=\"_blank\">Mods</a>
i ended up having to modify about every pipe possible...i did alot of welding today...anyways its all on and thanks for the helpJuiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
Originally posted by Kidcamaro98i ended up having to modify about every pipe possible...i did alot of welding today...anyways its all on and thanks for the help
so hows it feel ? hows da boost?www.turbov6camaro.com
i havent even started her yet lol.....tomarrow i gotta install the FMU and im waiting for my damn turbo oil lines to come in ....i wont be able to run any boost untill i get a 6Lb wastegate spring anyways...the one in it is 11 and thats too much to start off withJuiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
ok well i installed everything....and well im kinda pissed off.....my car WONT idol. If i start it and hold the gas pedal a little bit it will stay running but as soon as i let off it shuts right off....i dont have the turbo down pipe welded into my exhaust system yet. could that be why it doesnt idol??? also with the oil return/feed line kit i bought....i hooked it up by the way it seemed it would only hook up by...however i think its suposed to be the other way around....can someone please explain to me in detail about the oil return/feed lines.
i have the oil feed line figured out....its the oil return line im confused about. It seems too short to go to the oil pan? am i missing something??Last edited by Kidcamaro98; 05-17-2006, 10:45 PM.Juiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
idol IDOL [idol] an object, frequently an image, which is worshiped as a deity. Idols are usually found in human or animal form and may be treated as though alive; they are fed, bathed, anointed, crowned, and sometimes even provided with a consort.
Treaded is feed , should go to the top of turbo, the lager one is drain.
If you spin your turbo without oil.. , well order another one.
make sure your fmu is connected properly , you have HPT, just run the scan and youll see whats wrong
