ok i have the turbo mounted...and all the piping and intercooler...now which vaccum line do i attatch to the top of my blow off valve...also which vaccumm line do i also attatch to my wastegate?? theres a screw hole in the top of it and one on the side...i know one of them is for a boost controller...this is a HKS 40 MM wastegate....thanks alot
Andrew
Juiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
use the vaccum source behind the alternator, where your pcv valve (on the tb) connects too (ie follow the line from the TB to behind the alternator and you'll see the source) use t-fittings and vaccum lines to make the necessary entries. You can use this source for both the wastegate and the bov. the connection on the wastegate should be the bottom
1995 Black Firebird Turbo 3.8L<br />Custom FS Headers | AiResearch T04B | Tial 38mm | Bosch BOV | 30\" FMIC | 2.75\" IC pipes | 3\" Exhaust w/cutout | Flowmaster 80 | Walbro In-Tank 255LPH | 180* termo | Autometer Boost + A/F (phantom) | 36# GTP injectors
how aboout for the firebird can you put that turbo on and what r the things u need to turbo the car i so far have made a routing way for the turbo but dont know the things i need
