I currently own a 99 GTP and I am a former owner of a 95 Firebird. I miss the ttops, manual transmission, and last but not least, the rwd. My L67 is a lot faster then the 3.4 that was in the Firebird but not quite as fun to drive. I would like to own another 4th gen Fbody in the near future (2-3 years). Right now I am just doing some reseach on doing the full L67 swap, not top end. Yes I know that it will not be cheap to do this swap but the Firebird will just be a project/weekend car, so money/time is not important. I have a few questions that my search did not answer or I couldnt find.....
-How strong is the manual transmission? How strong is the automatic?
-How much horsepower can either hold until it needs to be strengthened?
-Has anyone swapped in the L67 block and mated it to the tranny successfully? Can it be done or are there any problems?
-Are there any hood problems on a 98+ car with the blower snout hitting it? The only problem I heard was the cowl.
-Has anyone run a top end m90 swaped stock car at the track yet?
ZZP put their m90 kit on an GT (L36) and it put down 253fwhp with only CAI, ubend/cat/resonator delete, which should be running mid to high 13s with that.
I already know about the Holden m90 being the best option for having the m90 swap. Its just too bad that the Gen V m90 wont fit because of its size which is about the size of a Gen III m90 with a TB.
The reason for doing the full out L67 swap is for a couple reasons of compression and already being built. Boosted cars like lower compression and KR is more dramatic. If an L36 had lets say 4*KR, that would equal around 10*KR on an L67. Since the engine is all put together, I would have everything needed. It would be easier stripping it to the block and then putting heads, manifold, and supercharger on. I have a DHP Powrtuner so tuning it wont be a problem.
Well thats all I have for questions now, but now Im off to research the headers for the car and see if they can be done......
