Re: Will a turbo kill mileage?
They really don't hurt so much which is why you are starting to see more and more 800+ hp Fbodys and Vettes, that are still maintaining 25mpg on the hiways. Because of the way the power curves work and turbo's work, you arn't really getting all that power unless you are on the gas. They can improve gas millage a little bit when tuned down in under powered cars. Its like towing a car with your blazer with a 2.8L and towing it with a identical blazar with a 4.3L down the hiway at 65mph. The bigger engine even though normally takes more gas has to work 1/2 as hard. But if you left them both stomped down the 4.3 would empty its tank really quick.
