Knowing full well that this is almost not worth the effort: is it possible to run 4 PSI on a turbocharger with little or no additional modifications to the engine?
4 PSI with no modifications?
Re: 4 PSI with no modifications?
better safe then sorry, there is no point in spending the time and money if you're not going to truely benefit from it and risk your bottom end at the same time91 Mustang LX 2.3 Turbo - T5<br />-daily driver, 210hp/300ft-lbs (outdated)<br />94 Ranger Splash 2.3 Turbo - T5<br />-serious build up, shooting for 400+hp<br />95 Camaro 3.4 auto -hers<br />-she\'s workin on it
Well, I was just curious, I didn't plan on doing a turbo without any modifications, but I was just wondering if it was possible.2000 Mystic Teal Firebird<br />Full 3\" exhaust, FRA, Aluminum Driveshaft
Tiago did his 3.4L dyno on 5psi because the wastgate was messed up and got 290whhp so it can be worth it as you said. but it all depends on the efficenty of the system. if its very efficent you could be sucking a lot of fuel at low boost and may need some upgrades. if its not very efficent you won't need as much fuel.
I have seen people run up to 9psi before they need to upgrade their fuel system.95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------> <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
4psi is nothing. It would be FINE.2004 CE Corvette 10.86@132mph
2011 Cadillac CTS-V
2006 Mitsubishi Eclipse GS
Originally posted by MuttledKnowing full well that this is almost not worth the effort: is it possible to run 4 PSI on a turbocharger with little or no additional modifications to the engine?www.turbov6camaro.com
1997 3800 Series II Camaro
