Fuel Pressure Reg. - FirebirdV6.com/CamaroV6.com Message Board
Fuel Pressure Reg.
  • Fuel Pressure Reg.
    Alright so the install is almost amongst us. Now since I am upgrading to external wastegate I need to go with an adjustable fuel pressure regulator, any suggestions? Also I need pics of wastegate setups, Since I will need to have a flange welded in for it. Thanks!
    Re: Fuel Pressure Reg.
    you dont need adjustable FPR, maybe FMU? unles you plan to crank the boost up
    pics are here: http://www.force-fed-fabrications.com/
      65Lb injectors, I dont need an FMU.
        you dont need FPR either :)
          Really? I was pretty convinced by others I would need one, what are the benifits from having one?
            Im not sure what boost are you runnning(your plans) but this is for the guys whos pushing the limits. According to the injector calculator you should be able to put 20+psi on 65s
            Viper:
            This is more for us high HP car with upgraded injecotors and fuel pump. this raise the fuel PSI on a 1:1 ratio with boost; and also lets you set your base FP higher.
              msd makes one with 1:1 boost referance
              www.turbov6camaro.com
              1997 3800 Series II Camaro
                do you think after T70, Abbottstg 3 heads, stattamma Stg3 cam, 65 lb injectors, 1.7 rockers, etc etc. would call for a FPR?
