exhaust question for turbo guys - FirebirdV6.com/CamaroV6.com Message Board
  • exhaust question for turbo guys
    How did you guys get around the low clearance issue when running a 3 inch exhaust all the way back? I have about 2 inches of clearance.
    Re: exhaust question for turbo guys
    I am having my pipes cut up for a custom fit to my 3 inch.
      bang it on ground and it will flaten out some :naughty: lol
      www.turbov6camaro.com
      1997 3800 Series II Camaro
        Mine runs over the crossmember as opposed to under :D
        1997 silver Camaro RS<br />|T-Type Powered|<br /><a href=\"http://www.kwfbody.com\" target=\"_blank\">Looking for a local F-Body club in K/W, Ontario, Canada?</a>
          you also have no ac
            if you look in my "need help fast" thread i ran into a issue too about clearance. Turned out to be the hardest part pretty much about the turbo. What side does your downpipe come down off the turbo...right or left?? (which way do you have the turbo mounted)
            Juiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
              mine comes down off the passenger side of the car. I was thinking about removing the ac like ravenp did but wasnt sure it would fit. If you have some pics of this could you please send them i would like to see them
                Mine runs down the firewall. The kit is up on the site under turbo firebird 3.8 kit for sale If you want to look at it.
                Making the world a faster place....... One car at a time.
                  Originally posted by viper04af
                  you also have no ac
                  Dont' need it, i have t tops :D
                    i was gonna take my AC out cause i have t-tops also, but that was a last resort if i couldnt get the turbo or anything else to fit...you should see if u can make it work without taking the AC out also
                      it has gotta go mine is so low i hit the brakes and it scrapes
                        um is the piping all the way up to the frame?? cause if not...theres room for improvement right there
                          i already decied to remove ac and go through there
                            Open downpipe sounded pretty good for me. I never really worried about exhaust, I enjoyed hearing my turbo spool up so loudly.
                            -Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open Downpipe
                              Mine used to scrape all the time. Now I have SLP SS springs and Bilsteins so it doesnt scrape as bad as it did before.
                              1997 Camaro Y87. Turbo.<br /><a href=\"http://pureoctaneracing.net/\" target=\"_blank\">Pure Octane Racing</a>
