i finally got most of the bugs worked out and got the exhaust welded but it hit on almost everything anyways....took it for a drive and can hear the turbo spin up but boost gauge never gets over 0 it idles at 20 on the vacuum side which is normal but when i try to boost it only goes up too 0. and i start getting a MAP sensor code 1601 and 1602 i think i wrote those down right. Got any suggestions? and would it make any difference if i havent changed the AFR down to around 12 to 1 yet?
No boost
Re: No boost
sound like you have leak in a intake pipewww.turbov6camaro.com
1997 3800 Series II Camaro
Re: No boost
Originally posted by Rjsok i checked all that stuff and tightened what i could now i only get a new wonderfull p0300 code just greatwww.turbov6camaro.com
Re: No boost
Originally posted by Rjsngk tr6's and i have rechecked my connections a dozen times i dont get it. maybe i got the wires messed up again or something what is the firing order again?www.turbov6camaro.com
Re: No boost
If you had your wires mixed up, you'd know it just starting the car.
Check the plugs... I get that code sometimes when i let off...and I know i'm super rich right now. I just know my plugs are fouled... will be replacing them before I get to testing again.1997 silver Camaro RS<br />|T-Type Powered|<br /><a href=\"http://www.kwfbody.com\" target=\"_blank\">Looking for a local F-Body club in K/W, Ontario, Canada?</a>
Re: No boost
i changed the firing order to what you said and i started throwing a 302 and 305 code i also noticed alot of water coming from the exhaust/turbo connection.... btw i changed the intake while i had everyhting apart if there is a leak code that be causing my problems?
Re: No boost
Originally posted by Rjsi changed the firing order to what you said and i started throwing a 302 and 305 code i also noticed alot of water coming from the exhaust/turbo connection.... btw i changed the intake while i had everyhting apart if there is a leak code that be causing my problems?
Yeah dude, look into that. You don't water hanging out in your exhaust turbine.-Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open Downpipe
Re: No boost
**** doesnt sound good91 Mustang LX 2.3 Turbo - T5<br />-daily driver, 210hp/300ft-lbs (outdated)<br />94 Ranger Splash 2.3 Turbo - T5<br />-serious build up, shooting for 400+hp<br />95 Camaro 3.4 auto -hers<br />-she\'s workin on it
