:banana: That's right, today I made a final decision for my cars turbo and it is a T - 70 Ceramic ball bearing Ptrim turbo with .70 A/R. WHEW! Abott heads are already in transit and all other pieces I already have in my room....Install is coming up soooo soon, then off to the dyno for 400+ rwhp !!! :banana:
Turbonetics T-70 Ceramic Ball Bearing
Re: Turbonetics T-70 Ceramic Ball Bearing
i have the .86 on my t70....after i had the downpipe welded on and a few things changed....my turbo is fully spooled at 2500 and it was a nice boost....when my car ran lolJuiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
:stp:
I decided to get the turbonetic t62-1 with .68 a/r exhaust; according to turbonetics' "turbo matrix" chart, that's good for up to 500 hp.
realistically, I'm only looking to get a bit over 300 on my car. lots of work to be done still.
I may have Corky's crew fab the pipe fittings and turbo manifold, since he's closer than Tiago. http://www.bellengineering.net/Last edited by kinetic; 06-16-2006, 01:09 PM.
Originally posted by Kidcamaro98i have the .86 on my t70....after i had the downpipe welded on and a few things changed....my turbo is fully spooled at 2500 and it was a nice boost....when my car ran lol
care to clarify!?!?THE ORIGINAL 3800SII turbo...<b><i>NOW SERIES-III</i></b>
sounds about right, i had a .68a/r on my car had full boost by 3200RPM1995 Black Firebird Turbo 3.8L<br />Custom FS Headers | AiResearch T04B | Tial 38mm | Bosch BOV | 30\" FMIC | 2.75\" IC pipes | 3\" Exhaust w/cutout | Flowmaster 80 | Walbro In-Tank 255LPH | 180* termo | Autometer Boost + A/F (phantom) | 36# GTP injectors
Originally posted by pr95blackbirdsounds about right, i had a .68a/r on my car had full boost by 3200RPM
btw.. what's the differences in the RPM band between the two?
i have a 3.8L, not sure what you are referring to in tersm of RPM band .. between the turbo's? or the 3.4 and 3.8l? if it's the engine size, i'm pretty sure they have the same rpm range ha ha if it's the turbo size.. .68 and .86 i'd say you'd only start seeing boost around 3500 with the larger size turbo.. plus on my .68 i could have full boost anywhere between 2700-3200 depending on how hard you give 'er1995 Black Firebird Turbo 3.8L<br />Custom FS Headers | AiResearch T04B | Tial 38mm | Bosch BOV | 30\" FMIC | 2.75\" IC pipes | 3\" Exhaust w/cutout | Flowmaster 80 | Walbro In-Tank 255LPH | 180* termo | Autometer Boost + A/F (phantom) | 36# GTP injectors
you will never spool that .86 hot side lolwww.turbov6camaro.com
1997 3800 Series II Camaro
Originally posted by UDLOSE98correction, it is .84 A/R on the hot side. and trust me, (CERAMIC BALL BEARING, heads, cam, 1.7 rockers, 65# injectors, etc etc.) this baby will spool up just fine.
what cam you have?www.turbov6camaro.com
Originally posted by UDLOSE98Stattamma Stg 3 turbo cam. and the 1.7's. I really didnt see an issue with the spool I mean I could still scale it back, it hasnt been shipped yet cause of the weekend.www.turbov6camaro.com
