Turbonetics T-70 Ceramic Ball Bearing
Re: Turbonetics T-70 Ceramic Ball Bearing
Originally posted by UDLOSE98
my grind is almost like the stage 4 grind :naughty:
i still say go with the .68 housingwww.turbov6camaro.com
1997 3800 Series II Camaro
don't know what he has, I have an M5 '94 3.4
what I'm wondering is what I would need to do to my engine to get it to around 300hp.
the engine: currently 120,680 miles (overhauled at 99K) no leaks, though I need to change the o2 sensors (I have them, and will change them shortly). pretty clean engine, aside from the dust
yet I realize I should probably get a compression test done, and have the tranny inspected, before I set any serious goals, and put the plan in motion; I may just get another car to put it on.
mine is A4, and wiht all my mods will spool just fine I am sure. As far as 300 hp, you are looking at bigger injectors, cam, and really that and 10-15 psi will already put you over the 300 mark. the guy I bought my turbo kit from was runninga t3/t4 at 15 psi on a completely stock motor BUT had race gas. He put down 359 rwhp. So pump gas, injectors, a cam or rockers and some boost will put you over.
Originally posted by UDLOSE98mine is A4, and wiht all my mods will spool just fine I am sure.
If you are using an A4 then amongst the mods mentioned you never stated stall? (forgive me if you did)...at any rate, with the size of the housing, the heads and cam package and the comp. wheel; you will definately need a stall converter looser than ~35XXRPM...THE ORIGINAL 3800SII turbo...<b><i>NOW SERIES-III</i></b>
Originally posted by nocuttWell "spool" has no standard...can you define what you mean by "will spool fine"?
yup i learned that the hard way !!! good thing i have one free stall coming to me !!!www.turbov6camaro.com
by spool I mean the time it takes or rather rpm range to get that turbo making its max PSI as controled by the wastegate and BC. As far as the stall, I havent listed one cause I am still trying to decide on the right one for my application, and it does seem like the 3600 is what it will be.
Originally posted by UDLOSE98by spool I mean the time it takes or rather rpm range to get that turbo making its max PSI as controled by the wastegate and BC. As far as the stall, I havent listed one cause I am still trying to decide on the right one for my application, and it does seem like the 3600 is what it will be...
So is this a street car...drag car or attempting to do both duties!?? I ask because you will need a compromise somewhere in between. Did StaT2 get you the turbo also? You should call and find out what the recommended stall should be...I guess more importantly; it will be based on how the first set of questions is/will be answered...
Originally posted by UDLOSE98...wait, less than 3500? I guess maybe I am not understanding the stall fully then.THE ORIGINAL 3800SII turbo...<b><i>NOW SERIES-III</i></b>
Originally posted by UDLOSE98well its gotta be my daily driver, so i am looking street and strip, I have read up on converters but dont understand the "slip" involved, guess I need to dig deeper.THE ORIGINAL 3800SII turbo...<b><i>NOW SERIES-III</i></b>
with my 3800 stall i can not spool the turbo at the line i need like a 4200 stall or 4400
this is with the old kit but tha car is broke anywaywww.turbov6camaro.com
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...6 days ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....2 weeks ago
