Could you attach a turbo to the headers via 1 or 2 exhaust clamps, or would they not form a strong enough seal?
Will exhaust clamps handle boost?
Re: Will exhaust clamps handle boost?
dont try lolwww.turbov6camaro.com
1997 3800 Series II Camaro
Seriously dude, horrible idea.-Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open Downpipe
I doubt it would explode...you would just make very small amounts of boost due to your catastrophic exhaust leak. :) Everything on a turbo setup is subject to high pressures. It's all got to be welded to work well.1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
