I have a 97 camaro rs, and have full cold air intake, tb spacer, full msd ignition, pace setter headers, magnaflow cat, & flow master exhaust, and I'm thinking of puting a supercharger or a turbocharger on, but would like to know which is better and what the hp gains would roughly be?
what should I go.
Re: what should I go.
Originally posted by blue nightI have a 97 camaro rs, and have full cold air intake, tb spacer, full msd ignition, pace setter headers, magnaflow cat, & flow master exhaust, and I'm thinking of puting a supercharger or a turbocharger on, but would like to know which is better and what the hp gains would roughly be?
But Turbo does produce more hp and tq than SC due to the absence of parasitic lost.
There are advantages and disadvantages to both of them. SC is easier to install and reliable than turbo. Turbos biggest advantage is its ability to produce more boost than SC.
sc's advantage is little to no lag (if lag is a problem) and advantage of being cheaper sometimes2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Originally posted by slow6sc's advantage is little to no lag (if lag is a problem) and advantage of being cheaper sometimes
most turbo also push more air the the SC kits that are out there....... and after installed are just as reliable as the supers are......
any fi car should look over the motor bay every 2 weeks (after everything is good) and look at bolts and stuff check them...... ect ....
it suck blowing a pipe off at 17 psi
kinda sounds like
BOOOM
only thing i see you need is like LSD........ dont get gears unless you your going turbo or sc.........
do you have auto or M5?www.turbov6camaro.com
1997 3800 Series II Camaro
yea, i know you have no turbo lag (even with a big turbo, as you have). I remember your old avatar/pic. Its just that you want the quickest 60 foot you can get.2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
your choice I say....both the powerdyne, custom turbo kit, cusotmer procharger kit or I would say hope my STS kit....Doesnt really matter what you will pick each of these will give really performance upgrade and can hit 12s...just depends how far you are willing to go into the 12s?2002 Firbird, <br />STS GT35mm-61 Turbo, HP Tuners, 3.73,UMI LCAS,UMI Panbar<br />Nitto NT555R P245/50R16 96v, NGK spark plugs t55, transgo shift kit, Jet servo
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...6 days ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....2 weeks ago
