Hey I was wondering what everyone else with a supercharger is using to use their A/C. right now im using a 110 inch belt and I can make full boost, but everytime I use the A/C it squeals and sounds like the belts about to come off. Do you guys have any special tensioners or is my belt too big? thanks
Supercharger help
Re: Supercharger help
Originally posted by derkyboy187Hey I was wondering what everyone else with a supercharger is using to use their A/C. right now im using a 110 inch belt and I can make full boost, but everytime I use the A/C it squeals and sounds like the belts about to come off. Do you guys have any special tensioners or is my belt too big? thanks
Yeah it sometimes feels like that. I wouldn't worry too much about it. Your AC is working right?
Originally posted by derkyboy187Its a dayco belt.....no my A/C does not work. What do you guys uses on your powerdynes?
It gets to be a 115* in my area. Today is 101*. But the belt does rattle a bit more and you can see that between the Alt. and Power Steering.
I know it's a hassle but try removing your SC and run the stock belt and then see if your AC is working fine.
Originally posted by derkyboy187Well I dont know if your belt route is different on your powerdyne or not but I have the Mach kit. What is the stock belt size?
But nevertheless, you guys do use a single belt like us PD users. Perhaps you want to check and see if that belt is slipping from that AC. Or it could be that this is a pre-condition already and your AC may not be working properly.
hey derkyboy please send me pictures of this kit on your car at wilbanks18@hotmail.com. I was wondering how it looks on the car?2002 Firbird, <br />STS GT35mm-61 Turbo, HP Tuners, 3.73,UMI LCAS,UMI Panbar<br />Nitto NT555R P245/50R16 96v, NGK spark plugs t55, transgo shift kit, Jet servo
Originally posted by derkyboy187Banks ill try to send you the pics when I borrow my friends camera.......well I took it off and the air conditioner works fine. should I try going to a smaller belt?
I would go for a shorter belt and then tighten it.
Good Luck.
well when my belt broke 2 months ago I had to have my car towed and the idiots took the tensioner off.....I did not know it till I turned the A/C that they did it then they denied they took it off so.....do you know of any belt tensioners for our cars?Last edited by derkyboy187; 06-29-2006, 11:25 AM.
Originally posted by derkyboy187well when my belt snapped 2 months ago I had to have my car towed and the idiots took the tensioner off.....I did not know it till I turned the A/C that they did it then they denied they took it off so.....do you know of any belt tensioners for our cars?
If it's just the pulley you can go to NAPA auto store. They have a pulley catalog that you can look at. Just be sure that you know the size and type of your pulley (smooth or ribbed) and the diameter of the hole.
I got one for $35 because my tensioner was burned out.
if you dont have a tensioner i bet thats your problem and its slipping on the AC pulley. if you need only the pulley go to NAPA but if you need the whole assembly check on here but chances are you mights have to go to a dealer or a junkyard'99 Camaro Y87 M5 T-tops
Flowmaster american thunder cat back, 2.5" magnaflow high flow cat, centerforce dual friction clutch
Car Domain
i didnt use a tensioner, but i went thru like 3 different belts and kept sizing further down and down once the belt got worn down. i think i have a 103 now. but i started at like 104.5Dave:
00 Supercharged Camaro - RIP
97 Turbo Camaro - Sold
Originally posted by dmw319i didnt use a tensioner, but i went thru like 3 different belts and kept sizing further down and down once the belt got worn down. i think i have a 103 now. but i started at like 104.5
I know that 103" is a tight fit and I remember how I had to muscle mine in there. But once it is use it stretches and you find that you have to tighten it with the tensioner a couple of times actually.
This probably explains why you say that your car lacks power.
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...6 days ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....2 weeks ago
