first off do yourself a favor and get a non-ebay turbo they are made cheaply and will fail much sooner then a more quality turbo, (i.e. mater power, turbonetics, garrett).
what do you need? Well that all depends on how much boost you plan on running, if you want to keep things cheap, run 5 psi or so. With that you just need the turbo and piping, which can be made by www.force-fed-fabrications.com . Other options would be boost gauges and boost controller, but these are not considered a must have. If you plan on running more boost then the list of mods goes on and on (heads, injectors, fuel pump, double roller timing, Bottom end (pistons, rods), push rods, cam, etc etc etc.)
not sure if he has anything used around. Watch the forums, pipes go up for sale every now and then from de-mods. Also I failed to mention you will need oil feed and return lines for the turbo, and a new cone filter for the intake
well im not exactly lucky, im in college in texas, and he just got transfered to Kansas City, MO. so if i want work done, its a **** of a drive... but hey if its gonna save me a few GRAND.. its worth the 500 miles. i mean if i can get a turbo for 250, and some good used piping, plus all the other smaller parts, im hoping for like 750-1000 dollars. then later i can get an intercooler and all that other stuff, but for right now i jsut want Power for as cheap as possible. all i have done is g2 cold air and a catback exhaust
i paid 4k for my T70 kit and once i convert to OB2 i should have no problem putting out around 500HP according to the guys tunning my car at GMR.
Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
