Powerdyne mounting bracket???? - FirebirdV6.com/CamaroV6.com Message Board
  • Powerdyne mounting bracket????
    got a project to help somebody out...anybody have a template (paper, cardboard, w/e) or spare, or one that i could borrow, copy and return to you...
    same with the modded belt tensioner???
    all help will be appreciated..
    thanks a bunch.
    dan
    Re: Powerdyne mounting bracket????
    might_thor I believe has the template....or grayman cant remeber check out one of t here websites.
    2002 Firbird, <br />STS GT35mm-61 Turbo, HP Tuners, 3.73,UMI LCAS,UMI Panbar<br />Nitto NT555R P245/50R16 96v, NGK spark plugs t55, transgo shift kit, Jet servo
      I don't have a template. But tell you what, I do have my SC out (preparing the car for smog test) and my brackets and stud bolts.
      I can go ahead and trace the brackets on a large paper and give you the dimensions to the stud bolts and such.
      I'll write down the other things that you need.
      I don't have the "L" bracket out though. But you can get that from Grayman's site.
      Also, I don't know what the gauge or metal thickness of the brackets. I can just measure the thickness and give the dimensions.
      You can basically take this to a machine shop and have them create these brackets for you.
      Just give me your address and I'll mail it to you.
        thats awesome...thanks, i'll send ya the $$ for postage and effort..
        sending pm..
        thanks,
        dan
          no pm priviledges....:(
          email sent..
          thanks.
          oh dang..just noticed that your from corona...im from highland/redlands area...
          i was the PM on the el cerrito intermediate school during construction, also did a bunch of work on Santiago HS....small world.
          peace
            email sent..
            thanks.
            peace
            Small world indeed. Don't worry postage, it's on me. I'm just going to trace the brackets as accurately as I can and write out the dimensions to the holes and such. I'll try and see if I can do it this weekend.
              thanks bro, anything u ever need from me u just let me know....
              i am sooooo impressed....
              :tup:
                any chance I could get those bracket tracings as well? I'll throw you some bucks via paypal if you'd like.
                  Sorry, everything is back in the car now. Perhaps Usd2sing can make you copies.
                    Edgar did a bang up job....
                    send me your addy and dont worry about postage. pay it forward somewhere down the line...same thing Edgar did with me...:tup:
                    thanks again Edgar.
                    peace
                    EDIT: suggestion......make a copy first, that way somebody else may benefit also....
                      No problem at all. I hope everything works out for you and your daughter. Let me know if you have any question.
                      Also be sure to checkout Grayman's site for all the information stuff you need. Good luck.
                        could this bracket be used to mount this to a 3.4 engine if not can anyone supply the bracket info for the 3.4 thanx tons
                          no it is a different setup on the 3.4
                          http://www.bowtiev6.com/
                            can the same sc be used though? if so i will fab a brackett up at work. Would i have to remove the ac completley? is that the desired location. if it is i will fab a bracket and the tb pipe and share the info?
                              Sent my address, I'll try to mock it up in AutoCad or Pro/E when I get it in the mail so we can distribute to whomever. Thanks.
