ok the oil doesnt drain fast enough into my oil pan....i get some smoke out of my exhaust once the car has been driving for like 10 minutes....now im wondering if i can buy a oil resivoir that i can hook up into the oil drain line to help it drain better???
im using 10w40 and the oil drain line is tapped into the driver side oil pan above the oil line
Juiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
let me start with *disclaimer* I don't have a turbo, BUT I have read about others having your problem and using some sort of restrictor on the line going into the turbo to slow the flow/pressure so that you don't have that problem
-Brad
2000 V-Star Custom 1100
:rock:
ok i thought the guy that worked on my car left left my oil feed the same. turns out i took it off and my restrictor wasnt there, so i put one back in. then i took a dial to the top of the turbo and its not level. Its 5* off...i dont know how much of a difference this would make for it to drain better if i put it at 0*?
i put the resistor in but it didnt make too much of a difference...where can i get a oil drain line rezzy??
