manual boost controller wont work - FirebirdV6.com/CamaroV6.com Message Board
  • manual boost controller wont work
    ok i have a turbosmart manual boost controller...as far as i know its hooked up right...but no matter how much i turn it up/down....the turbo only boosts to my wastegate spring rate (4psi) has anyone had this problem?? do we need a fuel cut defender to allow more boost on our cars?
    Juiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
    Re: manual boost controller wont work
    Its not hooked up right.
    If you have an internal wastegate, hook it up between the nipple on the wastegate and the nipple on the compressor housing.
    -Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open Downpipe
      he has an external
        i have a HKS external wastegate....and the boost controller instructions are only for an internal wastegate
          Does your turbo still have an internal wastegate attached? Is it bypassed?
          Try wastegate to compressor housing, boost controller in between, if thats not already how you have it hooked up.
            my turbo never had an internal wastegate......T-70
