Do need to do the throttle body pvc bypass? - FirebirdV6.com/CamaroV6.com Message Board
  • Do need to do the throttle body pvc bypass?
    Hi.
    I just brought a turbo kit from Perry, so I'm starting to set thing up before I get it. Viper04af already recommend me to buy the TR6IX spark plugs so they are in the to buy list. Also do I really need to do throttle body pvc bypass mod to run a 5-7 psi turbo set up? You guys already know what I'm talking about, but here is the link any. http://home.comcast.net/~grayman99/TB-PCV.htm. I'm new comer to the FI so I'm really excited to do this my self so any recommendation you guys have feel free to share it with me.
    Thanks a whole lot.
    Re: Do need to do the throttle body pvc bypass?
    you don't want to stick a turbo or SC on your Naturaly Aspirated engine without first converting the engine to run Forced Induction.
    yes, you need to plan on doing the PCV mod. If you don't do that mod you will presurize the INTERNAL block with positive boost. think about it.
    good luck with your project. g
    01 Firebird A4 3.42
    Powerdyne @ 6 PSI
    and other mods
      Hey stupid question here,
      But wouldnt a blow off valve do the trick?
      Camaro V6 - 14.3 @ 96mph
      Camaro SS - cam/boltons/m6/tune
      http://www.crfhq.com
        No. That serves a different purpose. Blowoff values open only when the throttle plate closes and pressure needs to be let out of the intake track. The pcv bypass prevents boosted intake from getting into the block and vents the normal crankcase pressure though another means than into the TB.
        1997 silver Camaro RS<br />|T-Type Powered|<br /><a href=\"http://www.kwfbody.com\" target=\"_blank\">Looking for a local F-Body club in K/W, Ontario, Canada?</a>
          I do recommend this...take me for example..I didnt do the mod and guess what...oil came out of the dip stick and went everywhere...so I learned the hardway...but hopfully you dont make the same mistake
          2002 Firbird, <br />STS GT35mm-61 Turbo, HP Tuners, 3.73,UMI LCAS,UMI Panbar<br />Nitto NT555R P245/50R16 96v, NGK spark plugs t55, transgo shift kit, Jet servo
            yup thats what happens
            i would do it the way i did with drilling the TB.. this way the PVC system still fuctions normal
            www.turbov6camaro.com
            1997 3800 Series II Camaro
              That is what I did and sealed up the hole with JB weld..works like a champ
