I'm thinking of buying a wilder for installing my turbo
Hi.
I was thinking of doing the turbo installation my self so I need a wilder the pipes together. The problem is I don't know how to wild at all, but I'm a fast learner. I was thinking of buying this wilder from sears. http://www.sears.com/sr/javasr/produ...seBVCookie=Yes. What you guys about this wilder is it a good buy and what thing should I buy for it?
Re: I'm thinking of buying a wilder for installing my turbo
Originally posted by BigRalph
Hi.
Thanks.
I don't think welding is that hard. You can take a semester of welding at your local college just do be sure that you develop your skills right.
But I think the real problem that you might have is bending the pipes accurately. Mandrel bending can be tricky.
Yeah the precise pipe bending is going to be the toughest part. When WELDING the pipes you need a tig WELDER because you are working with aluminum. A mig or arc WELDER will burn right thru aluminum. Tig WELDING takes a bit of skill too.
what aluminum, pipes are steel with an "aluminized" coating. Unless we are talking about intake piping and why use aluminum for that?
when it comes to the bends you could just buy some pre-bent peices from summit in various angles and use them to create your system. Just an idea.
-Brad
2000 V-Star Custom 1100
:rock:
if your just starting go with a lincoln pro mig 140 very good welder and it comes with a instruction video and book. It will cost between $500 and $600 though. Well worth it.
