Where I could find the Vaccum line, and fuel regulator line - FirebirdV6.com/CamaroV6.com Message Board
  • Where I could find the Vaccum line, and fuel regulator line
    Hi
    I'm wondering where could I find the Vaccum line, and the fuel regulator. The thing is I want to install a 5 way tee so I could connect the Vaccum line, fuel regulator, FMU, Boost gauge, and BOV from there. I tried looking for it in the Haynes book, but it doesn't explain where it is. I have a 2001 V6 Camaro if this helps. I really need the help.
    Thanks.
    Re: Where I could find the Vaccum line, and fuel regulator line
    Usually for us 98 and below we use the one that's from the TB.
    However I did switched and use the line that's at the back of the engine.
    If you're not sure where that is, there's a picture in Grayman's website.
      driver side at the back of the fuel rail...... above the big vac line that goes to the brake booster.......
      only small vac line back there
      www.turbov6camaro.com
      1997 3800 Series II Camaro
        does it matter which one to use?
