lost the engine! - FirebirdV6.com/CamaroV6.com Message Board
lost the engine!
  • lost the engine!
    well I spun a bearing :(
    In light of this I decided to ship my motor to Abbott racing and let Lance go to town on it and do a complete build!
    Should be gone a month. I hope to be installing it and tuning the car in late september :)
    Patrick<br />Sick Sixx Member<br /><b>97 Mystic Teal Camaro</b><br />425RWHP @14PSI<br />Old setup:<br />330RWHP @7PSI 13.9 @ 106.6 <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=4\" target=\"_blank\">Mods</a>
    Re: lost the engine!
    Sorry to hear that. I hope this fresh rebuild brings you into the 11's though!! :D
    1997 Camaro RS A4
    2006 Chevy Colorado
    2003 Kawasaki Ninja ZX6-R
      Here is the build plan. I shipped the engine off to Lance at Abbott Racing today....
      Rebuild Heads (Porting)
      L32 rods
      Diamond Pistons rings and pins
      Federal Mogul Performance main bearings
      Federal Mogul Performance rod bearings
      Federal Mogul cam bearings
      cometic gaskets
      ARP Rod Bolts
      ARP Main Studs
      Comp Cam: 218/218 528/528 114
      Comp 918 Valve springs
      Comp. Push rods
      Titanium retainers
      Comp OE lifters
      ARP heads studs
      Double roller timing chain
      Labor:
      Bore
      porting heads and intakes
      Hone
      Deck
      Install cam bearings freeze plugs and block balance shaft oil hole
      Assemble engine
      Balance crank rods and pistons
      Turn crank
        what kind of price do they charge for the full engine build?
        http://www.bowtiev6.com/
          www.turbov6camaro.com
          1997 3800 Series II Camaro
            like $3k or more.. i forgot, i had an estimate in my email but lost my email password
            I say do your own work
              gotta be more than that, the heads/pistons/rods will put you over 2K alone.
                yea, i was talking about labor
                Let me see if I can get that email back
                  ehhhhhhhh 3k labor!
                  I think I am gonna be sick.
                    Hey Linxs,
                    Not trying to be jerky or anything, but curious. (seen many spun bearings on the old 3800 in the past couple of years...seems more popular than just old rings blowing oil)
                    What was your rev limiter set at? did you keep it at the stock 5800 rpm or had you raised the rev limiter?
                    second question for group: do we have an oil pump that is sorta weak by high performance standards or something? is the stock oil pump putting out enough pressure under extreme loads? is it putting out enough pressure for the built or somewhat built engines or the forced induction crowd. I know not everyone spins a bearing but it does seem very popular.
                    sorrry to hear you gotta do all that work on your ride. i hope it all turns out great. good luck.
                    01 Firebird A4 3.42
                    Powerdyne @ 6 PSI
                    and other mods
                      Originally posted by grayman
                      blah blah blah blah......
                      I did the opposite, I blew my rings because of high AFRs.
                      I hydrolocked a cylinder and bent the rod.
                      A spun bearing would be my worst nightmare.
                      I would say that our oil pumps dont give enough pressure for the FI crowd. But you can just get an oil pressure kit and its good.
                        well i mean that is what I am doing...I am having lance rebuild my motor eventually dont care how much it costs cause when it comes to quality well that is worth more to me
                        2002 Firbird, <br />STS GT35mm-61 Turbo, HP Tuners, 3.73,UMI LCAS,UMI Panbar<br />Nitto NT555R P245/50R16 96v, NGK spark plugs t55, transgo shift kit, Jet servo
                          yea grayman, you can get oil pressure kits from zzp and intense-racing.com for the boosted people that want some more pressure. It is like 15-20 bucks or something like that
                            thanks for the tip.
                            01 Firebird A4 3.42
                            Powerdyne @ 6 PSI
                            and other mods
                              Hey about the oil pressure kits....
                              I did not see one at zzp but intense has one for 30 bucks. (OPK-671)
                              Anyway...they show a picture of the kit and also mention something about the oil filter elbow. where exactly does this kit go? my first conclusion is that the kit would modify the oil pump and that means gutting and tearing down the motor a bit to put the kit on. On the other hand they are talking about the oil filter elbow...is that all that needs to be removed? tell me it's that easy...please....
                              01 Firebird A4 3.42
                              Powerdyne @ 6 PSI
                              and other mods
