I finally decided to install my turbo on my 01 Camaro. My questions are: what is a good size injectors to run a 7-10 psi; also what is a good intank fuel pump that would hold the same psi?
your 2000+ year v6 vehicle requires modifications to the fuel rail as well as the electrical connectors in order to run bosch type injectors. you have some reading ahead of you.
01 Firebird A4 3.42
Powerdyne @ 6 PSI
and other mods
What type of injectors will fit on our cars with out any modifications? What about these type of injectors http://www.zzperformance.com/grand_p...ts1.php?id=249 will these fit our applications? I need to now because I'm about to buy some soon.
need info on your car.............. since this board dont alow sigs :tdown: :tdown: :tdown: :tdown:
I beleive you either use your stock injectors + FMU + pump, or get bigger injectors + pump + tuning because you have to tune to even be able to run the bigger injectors anyway.
Bigger injectors + tuning is safer than using the stockers and the FMU.
