why is it our sixes can only handle 10 psi whereas the import sixers are up to 35? are our motors really that brittle? sorry if this is a newb question :spank:
domestic vs import turbo pressure?
Re: domestic vs import turbo pressure?
Originally posted by Tradition_Fwhy is it our sixes can only handle 10 psi whereas the import sixers are up to 35? are our motors really that brittle? sorry if this is a newb question :spank:
Nissan 350z with 11:1 can only handle 5psi. They're really pushing it if they go higher.
Ours can handle 14psi without any changes to the internals. As long as fuel is adequate.
Skyliners and Supras can go up to 30psi.
Fastest LT1 with forged everything did 46psi Turbo.
Fastest LS1 with forged everything did 42psi with F1 ATi.
Originally posted by Mighty ThorA lot of money!!
Those forged stuff are not cheap. Plus oil pressure might be an issue for us.00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
So if i knew that i was going to to F/I later on would it be better if i took an engine out of a GTP?
TIA:banana:
'66 Ford SOLD
Originally posted by FireBird_Fr3akSo if i knew that i was going to to F/I later on would it be better if i took an engine out of a GTP?
TIA:banana:
1998 White Camaro 3800, A4, MagnaFlow Cat-Back, Zexel & 3.42's, Jet Chip Stage 2, Whisper Lid, and Ram Air.
why 30? the fastes car are only running 25 psi and are running mid 9's....... why 25 you have any idea how much that would cost? $30K at leastwww.turbov6camaro.com
1997 3800 Series II Camaro
first off you can take a morot out of a GTP, I am working on that projects right now.
Secondly 30 psi on our motors just isnt going to happen, the heads gasket would not come close to handling that much boost. thats to say you have forged everything.
