Trying to narrow down my turbo selection,I came to the relization that the biggest limiting factor for me would be the octane of pump gas.This will limit the amount of boost I can run,so I feel that if I select a turbo that will give max power at the highest boost pump gas will allow and with the fastest spool-up,itwould best serve my needs.What is the highest boost you can run on pump gas? This is for a 3.4 with forged pistons,iron heads and stock cam[which I believe is the same as a crane 2030]. I'm leaning toward a t3/t4oe .
Narrowing turbo selection
