Hello, 3.8 noob here with a couple ? - FirebirdV6.com/CamaroV6.com Message Board
  • Hello, 3.8 noob here with a couple ?
    Hi guys, great board ya got here. I'm not new to forced induction, but I am new to the 3.8 arena. I have a 97 with the 3.8 that is totally stock at the moment, and I'm looking to put a minimal effort turbo kit together for it. My plans are for a t3/t4 hybrid intercooled turbo, I'm planning on using an FMU for enrichment, and an MSD DIS6 for timing control. Here are the questions I haven't been able to find clear answers to by searching.
    Will the stock injectors support around 300 RWHP at 6 to 8 PSI with the FMU and a 255 LPH intank?
    WIll it even get to 300 RWHP at 6 to 8 PSI? What is realistic to expect here.
    Do you think I need a BOV with the auto?
    This will be a mild turbo application, and I want the small turbo cause I want boost to be almost instant.
    Re: Hello, 3.8 noob here with a couple ?
    You would probably want to go with T70 turbo. People have been able to put down 300rwhp with only 5-6psi. But they were running lean with just the FMU and stock injectors.
      T70 is too big if you are looking for a small turbo, you want like a 60trim.
      you dont need a BOV with an auto
      and welcome
        Thanks for the help so far, would the 24 lb injectors out of my Z do enough with the FMU, or would I need larger still?
        BTW, here is a link to my car domain, the info on intercooler pipe routing on page 3 may be of some benefit to the guys here, I've almost got my Z done and now I wanna work on the ol daily driver, I'm not looking for huge power out of it, but if I could stay with/ or beat a bolt on LS1 that would be great.
        http://www.cardomain.com/ride/848245/1
          get a t60-1
          get fuel pump
          get 36# injecotrs from GTP
          get HP Tuners
          go fast
          also you need a BOV it save's the turbo from bending the blades/shaft things
          www.turbov6camaro.com
          1997 3800 Series II Camaro
            Originally posted by viper04af
            get a t60-1
            get fuel pump
            get HP Tuners
            go fast
            Thanks, thats exactly what I was looking for, a quick short answer for the minimum requirements to put an entry level turbo kit on a 3.8.
              Is it cheaper to have a shop make a turbo kit? or is it cheaper to buy the FFF kit? or what would you suggest?
                get a quote from a shop
                  Can any mechanics shop make this or only special shops that speciale in forced induction? I'm just curious because I don't want to go my mechanic and try and get a quote on it and he just looks at me, gives a small laugh and then says "what an idiot" :(
                  Also, what type of price would I be looking at after purchasing the list of items that Viper stated in his above post?
                    i call every sshop within 800 miles of me most didn't even want to try and the rest wanted $5000 and up for the same kit FFF made me.....
                    if you get everything new i would at least 2000 just in parts
                      Has anyone thought of making an adapter plate out of 1/2 steel plate so you can swap the stock manifolds to thier opposite sides? I'm sure someone has thought of this, will it work or do the manifolds come out in places up front that make it not feasable, cause if the bolt patern is the only block, thats easy to deal with.
                        the bolts are in the heads custom is the best way
                          I know the bolts are in the heads, I'm talking about a 1/2 steel plate bolted to the heads with recessed bolt holes, then drill and tap the correct bolt patern into the steel plate to put the manifold from the opposite side to the steel plate. Similar to the adapters they sell for wheels.
                            what is fff?
                              force fed fabrications
