is it at all possible to run a turbo with the stock manifold on a 3.4l and just run the exhaust out of the manifold up to infront of the motor then back to the regualar exhaust track or maybe stick a turbo behind the motor and have enough room to run intercooler piping and a intake pipe? any suggestion's im only 17 so im trying to keep it as cheap as possible thank?
running with stock manifold?
Re: running with stock manifold?
it can definetly be done, in fact unless you have one custom made, thats all you are gonna get. Factory stock headers will be restrictive, so if you can find someone to fab up a kit for you, the better.
Originally posted by UDLOSE98it can definetly be done, in fact unless you have one custom made, thats all you are gonna get. Factory stock headers will be restrictive, so if you can find someone to fab up a kit for you, the better.
But it made the car sound better.
