is this all? - FirebirdV6.com/CamaroV6.com Message Board
is this all?
  • is this all?
    ok if i have my turbo, intercooler, all the plumbing including the exhaust plumbing and a megasquirt system is this all i need to begine my turbo process if not what else will i need right away?
    Re: is this all?
    :cry:
    ok ill make this post useful and ask what motor you have. search! this gets covered alllllllllll the time
      Re: is this all?
      oh boy. Im gonna guess you bought this all with no research?
        Re: is this all?
        ok well depends on what you mean begin turbo process?
        http://forum.camarov6.com/showthread...ighlight=turbo
        read that. i think that's the 4th time ive posted for people
          Re: is this all?
          youre missing all kinds of stuff dude
          Follow me!
          Or this
            Re: is this all?
            its on the 3.4l and i cant get an hp tuner with it unless i send it off like that forum says also i heard you dont need bigger fuel injectors unless u really give it some boost and the most ill ever run will be 10-12 also i saw it wont hurt with stock fuel pump and what is a wideband O2 and what exactly does the wastegate do?
              Re: is this all?
              wow, stock injectors wont go past 5 psi without a fuel management unit so you WILL need new fuel injector or a FMU.
              Your stock fuel pump will soon turn to no good, you WILL need to replace it.
              AND YOU WILL!!!!! need a wastegate, unless you have a small turbo and it is internally wastegated, if you dont know what a waste gate is, you are in some serious trouble. check out the thread on turbo dumps to read up on them a bit or www.howstuffworks.com
              do you have oil lines for the turbo?
                Re: is this all?
                oh and a wideband (another thing you gotta know fo before buying FI stuff) is used to tune your a/f ratio (air to fuel ratio) in conjunction with Mega Squirt. If you ask what the a/f is this thread may get locked.
                  Re: is this all?
                  whats the a/f?????
                  :p :p :p
                    Re: is this all?
                    Originally posted by Niko97RS
                    whats the a/f?????
                    :p :p :p
                      Re: is this all?
                      hahaha dan where did u get that pic hahahahaha.....
                      87 Firebird RIP
                      96 Camaro RS RIP
                      94 Patriot Red 1LE Z28 - Sold
                      02 WS6 TA - Sold
                        Re: is this all?
                        So do I need new injectors if i get a megasquirt system....and i finally found out what a wastegate is for sure lol and how much would a wideband o2 run me?
                          Re: is this all?
                          ok then say i have a turbo, wastegate, intercooler and piping and exhaust piping, BOV, megasquirt and a new fuel pump boost controol and boost gauge would i be set to install and would i be safe to run a 3.4 a 12psi?
                            Re: is this all?
                            you need a fuel management unit, not a new pump. bigger injectors are easiest. prolly want your turbo to last right? oil feed and return lines.
                            not to mention you need something to tune with... there's so much more im missing. but, no. you are not close. you need to learn before you jump into this
                              Re: is this all?
                              if he has any intentions of hitting 12 psi, he is gonna need the pump
                              • Manimal
                                Coil springs
                                by Manimal
                                6 days ago
                              • Manimal
                                Newby here
                                by Manimal
