GTP motor in a camaro?¿ - FirebirdV6.com/CamaroV6.com Message Board
  • GTP motor in a camaro?¿
    Ok I tried searching and found nothing is it possible to put a gtp motor in a camaro? Has anyone ever done it? also how would it fit in if they did cause the pulleys are on one side of the motor and the intake it on the other so would it be sideways in a camaro if possible maybe some pics or ore details on it....Thanks
    Re: GTP motor in a camaro?¿
    The bottom end will work for sure. I would think the heads will as well. The rest your better off swapping from the camaro. There's a few people on here that use a built L32 for their build ups.
      One person is currently making one fit.
      Short answer: Yes but you need lots of experience, knowledge and money. Oh and you have to fabricate parts that don't exist....
        for some reason I find it hard to believe you searched since this comes up about once a month already. Thanks for hitting the quota for January though. :)
        http://www.bowtiev6.com/
          actually um yea i did search there was never a straight answer always mainly like the heads of the motor or the supercharger or injectors i couldnt find the exact answer will it fit unless i overlooked it and what do u mean by the quota?
            I take it you never ventured to the FI section then.
            Quota of at least once a month someone asking if we can put a GTP engine/supercharger in our cars.
              this DOES come up all the time
              i just wrote up about it the other day, i will look for that thread....
                what would be a good thing to type in the search engine i typed gtp motor because everytime i type gtp motor in a camaro it has an error?
                EDIT* OK i typed GTP Swap and got some results sorry bout that
                  alot of engines will fit
                  just takes alot of $$, time, and custom fabrication
                  I know this fool that just put a L32 in his comoro, lucky bastage
                    lol, indeed he is, the bottom end isnt the issue, its the S/C thats the problem, and i am sure you have searched and found my big schpiel on that
