I got my hands on a Vortech V9 SC w/ 100 miles on it from a SEMA Pontiac G6 in toronto. Should be here in a week or so, then i will start fabbing up the bracket!!! I'm stoked.
Will someone please tell me how they tap their oil pan on the 3.4? Do the T-s that screw into the oil level sensor hole really work?
Its not a T , its a line that goes right in....and once i get mine up and running i will let you know how it works.
ya but dan...first you gonna get your car running ;)
Juiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
wrong...you actaully put a t-fitting in so oil can come from the block to both the turbo/SC and the pressure switch....and the you have to tap the pan for a drain line. the pressure side is easy....drilling and tapping the pan gettings a little interesting
Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
wrong again. read what he wrote. You don't T off where the oil line goes back into the oil pan. You T it for oil feel to the turbo/sc. He's referring to the return.
