Was on the Highway today and I stepped on it car accelerated smoothly and got into 6-7 psi of boost with no problem. Somewhere around 3rd gear and around 70 mph my SES started flashing, I backed off and the SES light went away. What can it be????
SES light flashed
SES light flashed
2001 JET BLACK V6 CAMARO <br /><br />-Powerdyne Supercharger, Pacesetter Headers, Transgo Shift Kit, and a whole lot more. <br /><br /> <a href=\"http://groups.msn.com/SPEEDSTYLEandPERFORMANCE\" target=\"_blank\">http://groups.msn.com/SPEEDSTYLEandPERFORMANCE</a> <br /> <a href=\"http://www.cardomain.com/id/camarostallion\" target=\"_blank\">http://www.cardomain.com/id/camarostallion</a>Tags: None
Re: SES light flashed
misfire is my first guess
was it stumbling? like...cutting out and possibly even shaking?
you could always get the code scanned2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Nope, wasn't stumbling. I do have a code scanner but, it flashed and then went away. So the scanner reads no codes.2001 JET BLACK V6 CAMARO <br /><br />-Powerdyne Supercharger, Pacesetter Headers, Transgo Shift Kit, and a whole lot more. <br /><br /> <a href=\"http://groups.msn.com/SPEEDSTYLEandPERFORMANCE\" target=\"_blank\">http://groups.msn.com/SPEEDSTYLEandPERFORMANCE</a> <br /> <a href=\"http://www.cardomain.com/id/camarostallion\" target=\"_blank\">http://www.cardomain.com/id/camarostallion</a>
1) fuel filter clogged (old)
2) bad spark plug gap
3) bad timing (doubtful)
4) damaged / weak ignition system components? (coils, ICM, etc)
5) bad wires
6) emissions system components bad
7) low or uneven compression
8) vacuum leak on intake or hoses
9) dirty fuel injector
Have you ever had your battery disconnected (or dead) for over 8 hours?
Then you would need a CASE relearn2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
problem fixed, number 4 wire wasn't on all the way!!!2001 JET BLACK V6 CAMARO <br /><br />-Powerdyne Supercharger, Pacesetter Headers, Transgo Shift Kit, and a whole lot more. <br /><br /> <a href=\"http://groups.msn.com/SPEEDSTYLEandPERFORMANCE\" target=\"_blank\">http://groups.msn.com/SPEEDSTYLEandPERFORMANCE</a> <br /> <a href=\"http://www.cardomain.com/id/camarostallion\" target=\"_blank\">http://www.cardomain.com/id/camarostallion</a>
