I am looking into a 6-9 psi setup from a Vortech v9. Are the bosch ones ok or do I need a GREddy? Are there any major differences, and also do different ones make different sounds?
which BOV
Re: which BOV
Originally posted by whiteThunderI am looking into a 6-9 psi setup from a Vortech v9. Are the bosch ones ok or do I need a GREddy? Are there any major differences, and also do different ones make different sounds?
Vortech BOV is pretty good and so is greddy.
Re: which BOV
bosch will probably work fine for you. besides if it does break they are only like 10-20 bucks on ebay, so it's not like its a big deal if it does die. Most people just want one that makes a loud noise or looks cool and to me there is no need for it. Granted if you are running higher levels of boost you might want a higher quality peice but for your levels it will probably not be an issue.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
