After checking the to4b 60-1 and the to4e 57 on "majestic maps", both had eff. in the 70+ % range Turbo Elements had a T3 60-1 and a T4 60-1 . This is for my 3.4 [43 lbs/min 14.7 psi /6000rpm's]. I'm favoring the T 60-1's. Is the diff. between them turbine size.Iknow they deliver more flow than the to4e 57.
Turbo Comp.
