Can someone explain to me how the vortech fmu worked on tiago's car with his turbo? Was the injectors, fuel pump, and fmu the only things he needed for fuel to acheive 300+whp?
vortech 6:1 fmu
Re: vortech 6:1 fmu
you need to add fuel when you add more air (aka BOOST) you need to upgrade the injectors, and pump when turboing anything. the fmu is a tuning option which increases the amount of fuel per pound of boost.Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
Re: vortech 6:1 fmu
Originally posted by White95you need to add fuel when you add more air (aka BOOST) you need to upgrade the injectors, and pump when turboing anything. the fmu is a tuning option which increases the amount of fuel per pound of boost.3.4l 500hp to wheels <br />still dreaming
Re: vortech 6:1 fmu
nope not ok you at the VERY least need a fmu. it is not adjustbale normally but they do sell adjustable ones. just depends on if want to drive around wondering if your going to lean out and blow your motor up. fuel is one area NOT to get cheap.Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
Re: vortech 6:1 fmu
as boost increase, the FMU increase the fuel flow at the rail. Gives you more fuel for that boost coming in. A 6:1 ratio fmu adds 6psi of fuel for every 1lb of boost
Re: vortech 6:1 fmu
Originally posted by 97rs4lifeas boost increase, the FMU increase the fuel flow at the rail. Gives you more fuel for that boost coming in. A 6:1 ratio fmu adds 6psi of fuel for every 1lb of boost3.4l 500hp to wheels <br />still dreaming
Re: vortech 6:1 fmu
well you will need the walbro high flow fuel pump to supply the fuel and if you are pushing to much through then you are going to max out the injectors as well
They have other ratio FMU's as well if you want more than the 6:1 ratio
Re: vortech 6:1 fmu
i would only go with a 6:1 or if you really want too a 8:1...i wouldnt go any higher tho...not good for the fuel lines.Juiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
Re: vortech 6:1 fmu
So 6:1 should be good for up to 15psi?Last edited by firebirdv6 3.4; 02-17-2007, 10:49 PM.3.4l 500hp to wheels <br />still dreaming
Re: vortech 6:1 fmu
i personally would go with the 8:1 but there is no sure way to tell whats good to a certain psi level. tiago ran a 6:1 bc he had the pump and injectors. he supplies a 8:1 with his kits. things like the condition your pump is in will affect flow as well meaning if your pump has a lot of miles on it my not put out the same flow as a newer pump.Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
Re: vortech 6:1 fmu
I have a 6:1 ratio Vortech fmu for sale in the for sale section just for a heads up ;)
Re: vortech 6:1 fmu
MSD makes a new setup...which automatically increase the amperage to your fuel pump when running a tc/sc...it's made specifically for boosted cars.....everything I've read on it claims that you do not need larger injectors or aftermarket fuel pump....This is what I'm going with for my setup for now....read more into it...
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...4 days ago
