Turbo question? - FirebirdV6.com/CamaroV6.com Message Board
Turbo question?
  • Turbo question?
    I just got a job working with diesel turbos and i was wondering if you could possilbly make these work on a 99 3.8 camaro.
    Re: Turbo question?
    a turbo is a turbo, its just gonna take more fabrication to make it fit.
      Re: Turbo question?
      Would you be able to use the same intercooler or would you need a smaller core?
        Re: Turbo question?
        an intercooler is an intercooler, alot of turbo diesel use aftercoolers though.
        size is going to be your biggest issue with both.
        maybe a turbo off a cummins 5.9 turbo diesel will work, they look about right or anyother turbo that size. see if you can get specs on the turbo.
        im in school to be a diesel tech, i play with turbo's all day long too.
          Re: Turbo question?
          keep in mind that most american diesel engines are built for big displacement low rev engines. the HUGE difference in applications is undoubtedly going to lead to differeneces in design of the turbo. will it work? probably, but make sure you do your research and find a turbo thats right for your v6.
