Hey guys, I'm in the process of building a rear mount turbo setup for my 95' Firebird 3.4L. I'll keep you guys posted on the progress....
Building a rear mount turbo setup
Re: Building a rear mount turbo setup
y not? its different no need for an intecooler, def will have some lag to it but it def keeps with a sleeper theme, plus lots of room
76 Camaro Rally Sport-355/TH350- Soon to be LT1/TH350 with a little laughing gas to wake it up...;)
89 Ram D350 CTD/M5- 1 Ton Dually getting 27 MPG's
Originally posted by TheGr8SchlotzkyI've always wanted to hear about one of these on a V6 f-bod.
Good luck! Keep us posted.
someone here already has ran it on the 3.8 ;)
Do a search and you will find the threads on it
Hey guys, my T4 turbo came friday, and my wastegate will be here sometime this week..Still have more stuff to get so this project probably won't be finished till sometime next month.....
I'm going to run an intercooler, that way I can get a little more HP out of this setup. Should run pretty good when all Dialed in...I'll get some pics up this week when I mount the turbo and start running the piping..
Hey Im in the process of doing this as well... i have the turbo intercooler bov external wastegate, boost controller, boost gauge, the intercooler piping and a flange kit, i just need to know where i can find a decent electric oil scavenging pump to run the oil back to the oil pan...I also have upgraded my brakes to cross drilled and slotted/vented rotors w/ ceramic pads. You need to make sure you do the PCV mod in ur throttle body by tapping the hole on the back side with a 3/8-16 tap and get a 3/8-16 set screw to plug it, and you need to put a filter in place of your oil filler cap as well. maybe u know about this already...not trying to jack your thread...but does anyone know where i can get that scavenge pump?
96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
is it just me or is it gonna be a bitc* to spool that T4 and actually make good boost effiently with it on a rear mount 3.4?? Not to mention, you will loose about 3-4 PSI between all the piping from the turbo through the intercooler and into the TBLast edited by Kidcamaro98; 03-08-2007, 11:35 AM.Juiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
motocross??? what do you race?? i race in District 3 in NY Quad Expert....my sister races the Womens class in district 34 on a KX100Juiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
