will I max out my 19lbs - FirebirdV6.com/CamaroV6.com Message Board
  • will I max out my 19lbs
    I have an NA car now, 3.4 , with 01' mustang gt bosch design 2 19 lb injecters, when i add my vortech (with tuning of course) will i be maxing out my injecters, and if so how will i know. I know this may be vague, so i can answer more questions if necessary. I see that everyone runs 24-36's so i was just wondering. the website says they support up to 300-340 ish hp
    Re: will I max out my 19lbs
    if you have a fuel management unit, you may squeek by, but just injectors, you may lean it out
      depends on boost level. higher rpm's u might run out of fuel. and adj. fpr and a high flow fuel pump should get u by.
        well just dont give it a WOT pass until you can afford new injectors, easier said than done but burnt pistons suck more than keeping your foot out of it a little :D
        76 Camaro Rally Sport-355/TH350- Soon to be LT1/TH350 with a little laughing gas to wake it up...;)
        89 Ram D350 CTD/M5- 1 Ton Dually getting 27 MPG's
          i'm going to be running 20psi on my set up and i have 65lb injectors. tiago ran 17lbs was the most he ran on 21lb injectors
          Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
            i have an adj, hollyey fpr now, so i have a shot with megasquirt tuning, 19lbs and only 8-10 psi? btw i'm tuning w/ megasquirt first my question is if i'm getting good reading from the tuning software, the injectors won't just die will they if i max them out?. but if i find myself leaning out up top at 6500 then i need bigger ones.
