what are the differences b/w these engines? I know that that they're both blown but which one's bottom end (really the only thing i'm concerned about) can take the bigger beating? Can you take an l32 rotating assembly (pistons rods and crank) and throw it into a L36 block without any modifications? i know compression is gonna be less by definition but it's built for boost. how much boost can these two guys handle?
I ask b/c i think it'd probably be easier to afford stock parts that will perform well rather than low production aftermarket parts...
2000 3.8L Camaro A4 Pewter Y87<br />K&N Filter, SLP Ram Air kit, Eibach Pro Kit, Flowmaster 80 series, Silverstars, NGK plugs and MSD Super Conductor Wires, Electric Water Pump
l32s have the better rods that can handle boost better. You can take a l32 rotating assembly and put it in the l36 block. All three blocks, l67, l32, l36 have the same block. Compression is lower in the l67 and l32 blocks compared to the l36 block as teh l36 is na
ok so please explain there are 2 l32's ones a 3.8 and one a 3.4. im also looking to get a new camaro and im going to turbo it which year 3.8 should i get
ps thx for the info
ps thx for the info
