hey i was just wondering if any1 knew what the effects would be on a STOCK motor if you were to install the powerdyne supercharger for a 2000 3.8 camaro(the one from LMPerformance). Would it completley f up the engine if you didn't get new spark plugs and injectors or upgrade cams, rockers, heads, ect. or is it just pretty much good 2 go right out of the box?
also to add, I know you will need to do some tuning with the engine to do this. Would the hypertech power programmer do the trick. or would you need something a little more "advanced"?
