Just wondering if any of you guys have installed the water injection pump right under your hood. If so, where did you put it? Do you have pictures? Can you just use your stock antifreeze tank like they say? Or do you recommend installing the tank and pump say in your trunk? Thanks.
I had my meth pump mounted to the frame rail near the passenger headlight. Made an "L" bracket that would bolt to the edge of the rail and hang straight down. The the pump bolts to the bracket. The stock tank works just fine as a reservoir
\'98 Camaro V6<br />Appearance... pleasing<br />Performance... just a little extra air.
