Hey guys what is going on. ok i have finally decided to put a turbo on the v6 :D however in the starting my parts list i have gotten stuck. First off i can't seem to fine #36 injectors? two, the Cam. i was looking though the cam bible and i came on Intence Stage 1X Turbo Cam and of course the ZZP GT1 Cam witch cam would be better? i am going to run about 10 PSI though Abbott Raceing heads ( stage 2 ) and last but not least after looking for the Valve train there are just so many to choose from Where is hands down the best place to get a new train, and sence abbott puts on 130 LB springs do i need to get a bigger timing chain and sprokits? thanks for the help.
Trying to get a list together for a turbo.
Re: Trying to get a list together for a turbo.
just get abbots FI cam
and you will need a double roller timing chain for those springs.www.turbov6camaro.com
1997 3800 Series II Camaro
go onto clubgp.com, you will find 36# gtp injectors for like 40-60 bucks
