I did a search and couldn't find anything. When I bought my turbo there was a debate as to whether the iat sensor shoudl be moved from behind the turbo/ic to infront of it to lower iat temps for the ecm.
Has this debate ever been solved? I moved mine to before the turbo...i wonder if that's part of my grief??
1997 silver Camaro RS<br />|T-Type Powered|<br /><a href=\"http://www.kwfbody.com\" target=\"_blank\">Looking for a local F-Body club in K/W, Ontario, Canada?</a>
Re: Boosted application: IAT before or after turbo?
I would defetnaily put it afther the turbo/IC so you acutlly get accurate temp readings. That will also keeping your power up considering you should keep more timing.
THanks... i've talk to a couple more people about this and htey both agree with you. I guess i'll be moving it back to just infront of the throttle body then :)
It's amazing how so many people can have different opinions on the same thing :)
