Hey guys,
I thought I'd start a thread of my build progress in case you guys were interested. I'm doing a complete rebuild which is 1st bussiness, then adding the ffh turbo as seen other posts.
Days 1&2 engine is stripped except for pistons, crank, cam. Those will be coming out tomorrow and the block will be getting bored and honed monday. At the same time I'm having the heads and intakes ported and polished.
Engine mods:
Swan high performance stroker rotating assembly.
valvetrain
Custom grind cammotion cam.
Comp cams Lifters
Manley 150# valve springs
INTENSE 3/8" oil restricted pushrods
New pushroad locks, seals, seats, bolts
Double roller timing chain
ARP head studs
ARP main studs
Doing all the obvious supportings mods too wideband, fuel system, trans, rear, etc. Shooting for 500+hp. :D
Lemme know if there's something I forgot on the Build and what you think of the setup. I'll keep updating as I go.
Engine mods:
valvetrain
Comp cams Lifters
ARP head studs
ARP main studs
