Am I missing something? TT Kit. - FirebirdV6.com/CamaroV6.com Message Board
  • Am I missing something? TT Kit.
    I was browsing around ebay a while back when I ran across a TT kit. Says that it includes just about everything. Here's what it says it includes:
    Including following item:
    -TWIN TURBO INTERCOOLER (22X3X11" CORE SIZE.30" OVERALL LENGTH. 2.5" INLET OUTLET)
    -t3/t4 internal wastegate turboX 2
    -blow off valve X2
    -oil line, oil return lines & fittingsX 2
    -universal 2.5" aluminum intercooler piping with silicone
    I regularly hear about $5k TT kits. These typically cost around (according to the seller) $900-1100. Here's the link.
    http://cgi.ebay.com/ebaymotors/84-93...spagenameZWDVW
    It does state this: "CUSTOMER IS REQUIRE TO CUSTOMIZE A TURBO MANIFOLD AND DOWN PIPE FOR THIS SET UP, THIS IS A SET WITH ALMOST EVERYTHING U NEED TO MAKE YOUR CAR TURBO"
    So someone please tell me, am I missing something?
    Originally posted by LETZRIDE
    I've never touched a rear end before
    Re: Am I missing something? TT Kit.
    yea that is a universal kit that comes with a few pipes and such and then you have to custom make it to work with your car. So modifying the pipes, adding parts and other stuff is involved. Not a bolt on kit by any means.
    Also they usually sell a crappy turbo with those kits and not a nice one that will be more reliable
    http://www.bowtiev6.com/
      i would be very careful about the turbo's they include. it says nothing about the trim of the turbo or brand. also like said before it is a universal kit only. the piping will only get you so far.
        Yeah, there is a reason there are only a couple TT v6 F-body's around, and they were fairly recent.
          I may just add to that list - unless I can find a single that is going to get me spooling when I want.
            As long as you get everything set up right. You shouldn't have a problem spooling single or twin.
              I know I had no problem spooling one, but the to4e maxed out at around 400hp on the 3.1 and was spooling fairly early. I'm going to a 3.4 and using heads from a 2004 3500, ported/polished, LS6 springs, nice large runners/plenum, splayed valves, and I will be seeing just under .5" lift. The restrictive iron heads I had before worked good with the turbo, but I don't know how good it will work on the new motor (besides the fact that it is an ebay unit).
              I could give you measurements for the new motor if you wouldn't mind helping me select a turbo(s). I also haven't started the headers yet, so I would appreciate any input. I know the 60* motor is a slightly different beast, but principals are the same.
                I don't have a problem giving my advice, just tell me what you got and what your goals are. If you wanna email me my email is timk@intense-racing.com
                  I will be getting to you soon. I have just finished cc'ing the stock heads and runners, but the plenum gave me a hard time and will be getting that number as well. Once I get the porting done, re-cc the heads and runners, I will be calling for a cam.
                    Those turbos are junk. Save the money and get some nice ones that way you only hafto do it once, and its done right.
                    Juiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
                      I used one with good results. They are fine for the shadetree mechanic without a lot of money.
                      No, they are not real Garretts, but the internals ire interchangable. If you got the cash, I agree, buy the good one first. I'm going with something new this time.
                        Forced Firebird...
                        You had TT on your 3.1 firebird right?
                        What #'s were you putting down?
                        1999 Camaro Z/28
                        1973 Firebird Formula
                          Originally posted by badinfluenceRS
                          Forced Firebird...
                          Single t3/t4. Never got to a dyno or the track before I was playing around with it, hit the rev limiter, and spun a bearing. After a minor rebuild, I did it again, but this time it sounded like a cannon and crushed the bearing like a penny on the train tracks I can tell you it was faster than any v8 3rd gen I've been in, and have been in lots since my first ride in one in 1987 (it was a brand new IROC at the time with a 350TPI), even with no posi.
                          I haven't decided if I'm going to use twins or a single on the new motor, just concentrating on getting the build done first (lots of time and money).
                          Here are some pics of the old setup that I sold (just kept the turbo)...
                          http://forum.camarov6.com/showthread.php?t=83253
                          I'm looking to get over 250hp N/A at 11.5:1 compression, then going to change to a turbo cam and dished pistons (to get about 8.6-8.9:1), and re-apply the turbo(s).
