Just wondering what numbers you guys are getting from your turbo set-ups. I'm looking into possibly turbo-ing my 97 Camaro, and am wondering what you guys with nearly stock 3.8's are running. I checked the timeslips, and there were only 2 or 3 3.8s, and they had more engine work done. Pretty much wondering what a standard turbo kit running 7-8psi on a stock internal motor will put out rwhp wise, rwtq wise, and 1/4 time and et wise.
Turbo Output
Re: Turbo Output
depends on the turbo size the t3/t4 the FFF came with was about 280-300 on 7-9 psi
i think 12 psi was 330 and 15 was 350
this was before HP Tuners came out tho so those numbers are dated but good estimateswww.turbov6camaro.com
1997 3800 Series II Camaro
Re: Turbo Output
Originally posted by RadRacerThat's what I'm looking at getting. The FFF under k-member kit with the 60mm t3/t4. Are those numbers to the wheel?www.turbov6camaro.com
Re: Turbo Output
Originally posted by Turbo V6 Camaroyeah RWHP... that was a 50 trim turbo.....~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Re: Turbo Output
Originally posted by RadRacersorry, but deals come and go, I can't figure out what I wanna do with my car. I just want it to be faster :D
but i really do think the turbo is the best option for the 3800. i mean check out highhp's bird! no doubt thats not your intent but it just shows what "some" turbo's can really do.
Re: Turbo Output
I never stopped getting crap for changing my mind... Each setup has it's advantages. Turbo is the most power to the wheels, stroker is a sick idea that hasn't been tried in an F-body to my knowledge. I have the L32 block but I might stroke it anyway. if the T56 kit comes cheap enough I may do turbo stroker. Stay tuned. Who knows what I'll do, I'm indecisive too\'97 Camaro M5 Y87 3.23 LSD, homebrew CAI, highfloCat, Flowmaster catback, Pacesetter headers, specstage3 clutch and aluminum flywheel, !egr, 2kW system.<br /><br />Possible L67 bottom end w/ abbott heads and a turbo in the works... gotta do more homework
Re: Turbo Output
Originally posted by JohnnyCstroker is a sick idea that hasn't been tried in an F-body to my knowledge.
http://www.fullthrottlev6.com/forums...hlight=strokersigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
Re: Turbo Output
there is so many factors but check out intense racing's bird. that runs 8's. obvously it's all about how much money and time you got. and remember usually the more radical the less streetable and reliable. my dyno time disappeared when i blew out 3 injector o-rings today. otherwise i could get you some better numbers.
